Results 1 to 6 of 6
Thread: NAE udp setting
    Feb 2007
    NAE udp setting
    where can I chaneg the UDP ( network port ) setting in a NAE?
    Feb 2007
    Sorry for the double post, I thought I canceled the other
    Jun 2007
    Not sure you can. If possible I'm interested.
    Ports
    Hello,
    I'm with kontrolthis on this. I don't think you can, but if you can, please let me also know.
    The only thing which I have changed in the past was the BACnet ID, BACnet of 47808 and the network address of 1001.
    Good question
    If you are taking about changing the web server port, the NAE 35 & 45's you can't. It is hard coded into the device. Actually with enough hacking I'm sure you could, but I don't think it would be worth the time.
    I believe on the NAE55's you can change the web server port, but I'm not 100% positive on that. Now if you're talking about changing the Bacnet port on the NAE and it is not connected to a site director, you go to the site, click on the advanced radio button and down near the bottom there is a box for setting up your BBMD and you can set your UDP port for the Bacnet router/BBMD in there.
    Sep 2006
    Alaska
    NCM
    I know on an NCM you change the UDP. But on a NAE I think Johnson took away that ability.
    Law Of The Thermostat: He who has the thermostat wins!!!!!
