Thread: NAE udp setting
06-18-2012, 06:16 PM #1
- Feb 2007
- 239
NAE udp setting
where can I chaneg the UDP ( network port ) setting in a NAE?
06-18-2012, 06:17 PM #2
- Feb 2007
- 239
Sorry for the double post, I thought I canceled the other
06-19-2012, 01:33 AM #3
- Jun 2007
- 134
Not sure you can. If possible I'm interested.
06-19-2012, 07:34 AM #4
- May 2006
- 559
Ports
Hello,
I'm with kontrolthis on this. I don't think you can, but if you can, please let me also know.
The only thing which I have changed in the past was the BACnet ID, BACnet of 47808 and the network address of 1001.
Good question
06-19-2012, 10:57 AM #5
If you are taking about changing the web server port, the NAE 35 & 45's you can't. It is hard coded into the device. Actually with enough hacking I'm sure you could, but I don't think it would be worth the time.
I believe on the NAE55's you can change the web server port, but I'm not 100% positive on that. Now if you're talking about changing the Bacnet port on the NAE and it is not connected to a site director, you go to the site, click on the advanced radio button and down near the bottom there is a box for setting up your BBMD and you can set your UDP port for the Bacnet router/BBMD in there.
06-26-2012, 06:44 PM #6
NCM
I know on an NCM you change the UDP. But on a NAE I think Johnson took away that ability.
