Results 1 to 4 of 4
    One room cooler then others
    I have central AC and one bedroom is colder in the winter and warmer in the summer then the rest of the house. Winter is not a big problem, because we can just turn the heat up, but in the summer, the AC until runs all day and the rest of the house does not get cooler then 78 degrees (say 90 degrees outside).
    The air is cold coming out of vent, and is there a way to tunr up the AC so it blows the air stronger? It seems that the AC out of the vent in spare bedroom is not as strong as other vents.
    Any ideas?
    Tim
    east central indiana
    Sounds like you need some ductwork. Couldn't tell you what specifically without seeing it.
    Also sounds like possibly some trouble with the A/C. Yep.
    I recommend to you a service call. A competent technician will know what to look for.
    This space for rent.
    Fort Worth, TX
    Changed your filter, lately?
    Building Physics Rule #2:
    Building Physics Rule #3:
    SW FL
    Thumbs up Maintenance call
    Quote Originally Posted by timchi29 View Post
    , but in the summer, the AC until runs all day and the rest of the house does not get cooler then 78 degrees (say 90 degrees outside). Any ideas? Tim
    It sounds like you need maintenance ( or new unit, if > 14 years old)
    to improve A/C system performance
    if the unit can not maintain 75'F when it is 90'F outside.
    Window size(s) in the bedroom with inadequate air flow?
    Diffuser and Duct sizes?
    Unit size?
    Size of House?
    Summer and winter electric bills?
    Location? TX or MN
    In other words, call for maintenance and evaluation
    Designer Dan
