Results 1 to 12 of 12
Thread: Caliper for ID and OD of pipe
07-22-2006, 12:42 PM #1
- Jan 2006
- 34
My instructor has a caliper for measuring the inner and outer diameter of pipe. I've looked all over and can't find one. Do any of you have any links?
07-22-2006, 01:15 PM #2
- Jan 2002
- tip of the mitt
- 1,873
Check with dan holohan at the heating help forum. He has something like that in his catalog.
I have my own little world. But it's OK...they know me here.
07-22-2006, 01:17 PM #3
- May 2005
- Western Kansas
- 255
07-22-2006, 01:40 PM #4
General part # 729.
call URI, they will have or can get.
07-22-2006, 03:28 PM #5
Why would anyone need a caliper to measure pipe? Especially an instructor.
07-22-2006, 07:43 PM #6
your local supply house should have one....or a local hardware store...possibly sears or an auto parts store....
07-23-2006, 06:38 AM #7
Professional Member*
- Nov 2004
- SW FL
- 5,252
Right,Originally posted by hvacmd2002
EYE ( or I ) is a Great Instrument ...
Calibrate it and use it.
Recalibrate as necessary.
Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
07-23-2006, 10:08 AM #8
- Jan 2006
- 34
I am still getting a feel for this stuff. I would rather take the time to pull out a caliper and have the exact size than to make a mistake.Originally posted by hvacmd2002
07-23-2006, 10:46 PM #9
- Jun 2006
- 450
You might be the person looking for an x SCH 40 pipe clamp and find that "they" don't make one, BUT a y tubing clamp is really an x pipe clamp. Confusing.. yes. I'll agree.
Did you really find that metric adjustable wrench you were looking for? <G>.
07-23-2006, 11:20 PM #10
Not the greatest way, but a cresent wrench works mighty good in a pinch..(well, one with the wrench size on the side with a neat little arrow that points to the size).
"If you call that hard work, a koalas life would look heroic."
VETO PRO PAC, The Official Tool Bag of HVAC-Talk.com
Testo... you guys rule!
07-24-2006, 07:11 AM #11
- Feb 2003
- northwest of Atlanta, for now
- 273
3/8" is easy
5/16" isn't.
All I do is use a crescent wrench around the outside of the pipe. I twist it a bit to make sure the pipe is round and then I measure the opening of the wrench to see the measurement.
Usually, the Mark 1 eyeball is perfect, but there are times I need additional verification.
BTW, the 'rocket' tool Dan Holohan sells is for iron pipe, I think.
http://www.heatinghelp.com/shopcart/...?category=5-43
07-24-2006, 09:24 AM #12
- Feb 2003
- Huntsville,AL
- 4,125
inexpensive calipers at harbor freight, Sears, auto parts stores, WWGrainger, McMasterCar, ___
Understand that the distributor clerks will probably not know the actual measurements!
When you have looked at 200pc of pipe & tubing, you will know by visual inspection a pipe's size.
steel pipe comes in tubing thickness [like elec conduit & fire sprinkler thinwall {Sch30 ?)], Sch40, Sch80, Extra Heavy wall, etc__harvest rainwater,make SHADE,R75/50/30= roof/wall/floor, use HVAC mastic,caulk all wall seams!
