    dallas
    Would love some advice from you guys.....New house about 6 months old...Have a lennox model# 13acc-060-230 which if i understand most of you guys would be a 5 ton unit?....have been watching the unit over the past 2 hours and almost to a minute the system kicks on ....runs 10 minutes, turns off for 10 minutes, then kicks back on....the reading at the tstat never changes...does this sound normal to you guys?.....from reading some of the post on here, sounds like the unit may be oversized for a 2300 sq ft single story house....any help you may give would be greatly appreciated
    Nov 2005
    Brownbakistan
    ask your builder for the load calc.
    5 ton for 2300 sq ft does sound a bit over sized.
    What do you have the stat set for, and what is the out door temp when it is cycling like this.
