Page 3 of 9 FirstFirst 123456789 LastLast
Results 27 to 39 of 107
  1. #27
    Feb 2012
    this isnt a question of if the crap should be replaced. it's just if what i asked is possible...and if anyone have seen it
  2. #28
    Dec 2008
    Buffalo NY
    Quote Originally Posted by philstanley1 View Post
    qwerty hvac.... i know it's old... but i have replaced condensing units for this property owner in the past, with no problems. i am not asking for anyone's diagnosis@pascone 10
    i was just curious if it was possible to have a leak in one direction and not the other.
    I was saying your issue is the mismatch. That is why it is hissing. If the Condenser is new then it is at least 13. Seer. The evap you have is probably 8 seer. They just won't work together and may cause the symptom you describe. Just trying to help but you need to give us more to go on also.
    Sent from my iPad using Tapatalk HD
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
  3. #29
    Etters PA.
    I posted a scenario other than that its not going to happen. your micron gage doesn't lie if your hoses and gauges don't leek and a system with nitro doesn't lie either if your hoses and gauges don't leek period. proper procedures is the answer.
  4. #30
    Dec 2011
    somewhere between here and there
    so now you are blowing thru a cone????
    the hissing sound is prolly the liquid boiling before its supposed to
    but why are you lowing thru a cone ???????
    and what does blowing thru a cone have to do with vacuum?????
    Please, Please Please......keep the Factory Smoke in the Wires!!!!!
    Is it Rum'Oclock yet???
  5. #31
    Dec 2011
    oyah...also....you will get the same amount of air thru said cone....no matter which end you blow thru.....
  6. #32
    Feb 2012
    @bigbacardi
    ever take physics in college? doubtful
  7. #33
    Dec 2011
    lol.....what is the only thing that restrics the amount of air thru a pipe/cone/hole????
    mr physics man.....
  8. #34
    Dec 2011
    that would be noise....for us morons who did not take physics
  9. #35
    Dec 2011
    and now a physics major has to ask us if a leak can happen one way????
    also said physics major also talks about positive pressure????like negative pressure exists?????
    then whines about being heckled???
  10. #36
    Feb 2012
    like negative pressure exists?.... vacuum is negative pressure
  11. #37
    May 2011
    Ripley, WV
    Phil what is your Superheat? also what about the indoor entering wet bulb and outdoor dry bulb temperatures? Thanks.
  12. #38
    Dec 2011
    omg...really.....negative pressure is vacuum???
    how is minus fifteen pounds per square inch possible?????
    please torque the wheels on my car to negative 35 psi!!!!
    hahahahahahahaha
    you just exposed your weakness.....you are an engineer
    you prolly know how to draw a 10 inch pipe that goes thru a 8 inch hole!!!!!!
    omgh
  13. #39
    In a boiler room
    Philstanley, did you measure super heat and subcool? If you would post those numbers you would not get "heckled", you would get answers.
