Results 1 to 13 of 16
Thread: Manitowoc
    NW AR
    Manitowoc
    QD692N
    010364563
    Remote condenser.
    Keeps locking out on excess harvest time. I clocked it today at 3 mins and 45 secs to drop. Makes a nice even sheet of cubes. The top of the sheet is coming off fine, the bottom isnt.
    I adjusted the thickness probe and got it to drop in 3 mins flat. Thats too long. Its going to lock out again. Any ideas?
    NW AR
    It is spotless. Plate is smooth, no black anywhere, no scale deposits.
    Nov 2010
    Missouri
    Smile
    Quote Originally Posted by ar_hvac_man View Post
    1-800-5455720 that is the Manitowoc tech line. They are a great help now and then
    NW AR
    Ugh, tech support? Thanks. Do they speak decent english?
    Jun 2012
    Tenn
    http://icemakerpartsshop.com/article...c-ice-machine/
    I checked this out once, and even checked the switch and counted the flashes, but it was the bin switch.
    Jul 2000
    Treasure Coast/Florida
    QD692N
    010364563
    Remote condenser.
    An evaporator can "look" clean, but it's always a good idea to give it a proper cleaning before attempting to diagnose a problem like this.
    If cleaning fails to resolve it, this machine, being a Q-Series remote, has a harvest pressure regulator (HPR) which may (or may not) be a cause. Check your suction pressure during harvest. It should gradually climb to around 90 psig or so. If it stays down around 60-70, there's not enough heat going to the evaporator. Then it's time for a new one.
    Jul 2010
    So-Cal
    Quote Originally Posted by icemeister View Post
    maine
    im with ice on this.. also check the weep holes on the plate.. those hpr system are tricky if your not fimilar..
    Yes if you call tech support they speak english there located in Mainitowoc Wisconsin
    Dec 2010
    Woodbridge Twp, NJ
    Hell, the guy who you would speak with is on here, actually.
    Oh JON BAILEY!!!!!!!!
    Every customer you take for granted today will be someone else's tomorrow.
    Apr 2012
    winnipeg
    is it level..... lean it to the front...... I had a few with same problem... let gravity take over and all was well
    Jun 2012
    Afghanistan
    Remember to use your Manitowoc Service Tech Book. If you don't have one I urge you to get one. It has all the answers and makes troubleshooting faster and accurate.
    Dec 2011
    Michigan
    Clean it!
    Then time it. If it's still to long check the evap for loose plates. If that checks out I like to hold a flashlight against the plate and look for cracks where the plates attach to the back. What are your pressures in harvest?
    Sent from my amazing 4G device
    NW AR
    It was cleaned from top to bottom less than a year ago when I moved it from one store and installed it in another. The former store got a new in box unit that I installed as well.
    About 2 months ago I get a call and they want me to come move it, that day. I couldnt make it that day so they called someone else to move it. I checked yesterday and the filter drier is the same one I put in when I installed it.
    I generally dont even pull my gauges out of the truck on ice machine calls. I will today or tomorrow and check pressures.
