Results 14 to 26 of 32
Thread: yk disaster
    Dec 2008
    Dixiana, AL
    I assume that regular vibration analysis likely have caught the bearing wear before failure? Or was this unit overdue for a rebuild?
    You're assuming that there was bearing wear. It could have been that, as well as several other things.
    Apr 2012
    Paper Street Soap Company
    Quote Originally Posted by nyrb View Post
    Did it look something like this?? You're in for a fun time.
    I bet any one within a 50 yard radius of that went home with bleeding ears that day
    Quote Originally Posted by klove View Post
    What else could it have been? We've covered the high speed thrust and journal. Could it have been the impeller nose seal was set up wrong to begin with or came loose? I haven't seen the insides of a YK, so I am running out of ideas
    The key to happiness is lower expectations.
    Don't pick the fly crap out of the pepper.
    Dec 2008
    Dixiana, AL
    Quote Originally Posted by Tech Rob View Post
    The list of reasons that something like that can happen is long and varied, and a lot of times includes multiple issues simultaneously that can culminate in a bad end result. I've seen it on Yorks, but never on a Trane. One reason (I believe) is that the impeller seals on Yorks are much tighter tolerance than Tranes. Either of the items that you mentioned are viable reasons.
    Jun 2012
    RAVAI China 2012
    RAVAI China 2012 will be held at Canton Fair Complex from August 21-23, 2012. As an important exchange platform for the professional buyers and enterprises worldwide, it's become one of promising potential exhibition in RVAC industry. To meet the needs, the exhibiting space of RAVAI China 2012 will be expanded to 30000 square meters; we are inviting over 600 exhibitors at home and abroad, cooperating with 40 domestic and overseas organizations, 300 worldwide industry media for promotion.
    Vic Chan
    Guangzhou Grandeur Exhibition Services Co., Ltd.
    Tel: +86 20-28961166
    Fax: +86 20-82579220
    E-mail: sales10@grandeurhk.com
    Website: www.avaichina.com
    Dec 2008
    Dixiana, AL
    Brace yourself, Vice. You're probably going to hear from some folks about the site rules, which you should have read and understood before posting.
    Jun 2012
    so cal
    i took it apart checked the thrust its in range. i think that either the impeller broke (highly unlikely) or the nose seal came apart. the nose seal doesnt actually have to set up like a trane its floating on springs and self centers. now when the machine was surging for yaers before and thrust bearings were changed its hard to say how many times it surged. i also found the nose seals mounting bols sheared off? could it have beed the cause of the failure or result of it. the funny part is no one new it was tripped it was off on high oil temp go figure.
    Not in Iran
    does this mean i cant advertise? damn !!
    anyways this is a great post covering the damages of the inside of a machine.,
    i know that the trane is running around 3500 rpm
    compared to the york at about 35000 rpm., hince: size,
    i guess that the diff in rpm would be the reasonong behind the tighter tolerances ,.
    however i am not a pro and i am running ideas through my tiny tiny brain as well.
    ,. another spelling flaw., tiny = small
    tinny = even smaller than tiny .,
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    Aug 2009
    Prattville, Alabama
    I was thinking of the difference in speed too, Milkyway. And I also like reading these types of threads, especially about equipment I'm not familiar with.
    nose seal clearances don't have any direct relationship to speed. they have to do with pressure increases across the impeller...greater pressure increases equal greater leakage from the high side of the impeller to the low side of the impeller. the greater the leakage, the less efficient the compressor. with the york, there is a greater pressure increase across that 1 impeller versus the 2 or 3 across the trane.
    also, the pressure increase across a 1 impeller, R134a is going to be a lot higher than across a 3 impeller R123 chiller.
    Somewhere in the world.
    York doesn't run at 35000 rpm that would be more like a McQuay high speed or as we would say screamer Yorks are more in the 12000-15000 range.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Not in Iran
    Quote Originally Posted by york56 View Post
    thx
    Aug 2009
    Prattville, Alabama
    Yeah, thanks, Jay and York56.
