Manufacturers group their brochures and associated SEER brag based on the highest efficiency of the various combinations in that group of units. Normally there are either 4 or 7 sizes, depending on whether they're 2-stage or 1-stage, 7 being 1-stage. The only exception to the groups is 13-SEER, which is the federal minimum efficiency. Once a unit breaks through the level, all bets are off on what the ACTUAL efficiency is in a GROUP of units. In practice, the larger systems get the lowest SEER/EER/HSPF ratings.
If you're truly interested in the ACTUAL SEER/EER rating of your equipment combination, you have two resources where you can glean that information. The manufacturer has it all as does the AHRI.org. Take your choice.
