Results 1 to 13 of 18
06-11-2012, 09:31 PM #1
New Guest
- Jun 2012
- 3
Expansion Valve Requires New Freon?
I have a quick question I'm hoping someone can answer for me. I recently had my A/C stop blowing cold air (happened suddenly, one day it was cold and the next it was warm) and a service tech came out to check it yesterday. He told me that the expansion valve is no good and that it will need to be replaced along with the freon. I asked him if the unit still had freon and he said it was full, but he recommended replacing the freon completely as there could be contamination in the line from the bad valve.
My question is does this sound like a line to get me to spend more cash? I have a 12 lbs. R-22 unit so the freon won't be cheap. Is it really necessary or at least a good idea to replace the freon?
06-11-2012, 09:35 PM #2
Not necessary to replace the refrigerant unless it is contaminated.
Very unlikely that a bad TXV caused contamination, HOWEVER, contaminated refrigerant CAN cause a bad TXV.
06-11-2012, 09:38 PM #3
New Guest
- Jun 2012
- 3
Thanks for replying jpsmith. Would a technician be able to somehow check for contaminated freon or would it be better to just play it safe and let them replace it?
06-11-2012, 09:38 PM #4
my professional opinion would be the refrigerant you allready own would be happy to work with the new valve... the other thing if the expansion valve is defective how on earth was it determined the system was full....
06-11-2012, 09:38 PM #5
Ooooh 12 pounds of R22 is going to sting a bit.
Ask him exactly what is contaminating your R22 ? If the TXV didn't cause a compressor burn out there would be no reason to replace that refrigerant.
Honestly I wouldn't deal with that guy. He's not being honest.
It's not motor oil, it doesn't have to swapped out every 300 miles
06-11-2012, 09:40 PM #6
06-11-2012, 09:43 PM #7
No reason to not reuse the refrigerant, a bad TXV won't damage/harm the refrigerant.
06-11-2012, 09:43 PM #8
06-11-2012, 09:44 PM #9
New Guest
- Jun 2012
- 3
Thanks for all the replies everyone. The compressor is definitely not bad so it sounds like this guy is trying to swindle me. I'll go ahead and get another technician out here and see what they have to say about the situation.
06-11-2012, 09:44 PM #10
In the past, I've always assumed that any system I didn't know the installation and service history of had been subject to poor installation and service practices.
While that is usually a safe assumption in my part of the world, the price of refrigerant these days has been making me rethink things in some cases...If more government is the answer, then it's a really stupid question.
06-11-2012, 09:44 PM #11
That would be a good Idea....
06-11-2012, 09:49 PM #12
06-11-2012, 09:51 PM #13
