Results 1 to 13 of 14
    Sep 2010
    Big Block of Ice
    Looking for ideas to thaw ice and replace a defective drain pan heater. Coil 20 ft in air. Pan a solid block of ice about 10ft long x 1ftwide x 6in deep . 0deg in room/warehouse. I need to get old heater out new one in. Have manlift to access.Drainline is ok
    May 2003
    Utah
    Cool
    Make sure the drain is clear...then get a hose with hot water (low
    water flow) and melt the ice.
    Oh, might want to round up a fork lift too.
    I've been tinkering with a small submersible pump in a large trash barrel with a short hose.
    Works OK.
    Dec 2000
    Flat Rock, NC
    Tap the bottom of the pan w/ 3lb hammer gently breaking the grip of the ice from the pan undo the union that is supposed to be on drain and lower pan. break out rest of ice w/ hammer then use hot water for balance. should take 2-4 hours.
    maine
    Quote Originally Posted by codgy View Post
    Thats what i do i use the 3lb and hit a block of wood so i dont dent the pan then pull it out in pieces and melt the rest
    Jun 2012
    Queens, New York
    Electric heat gun works great on melting ice on coils and pans.
    NH
    Cut drain line or break union. Disconect heater. Drop drain pan, and take outside dump some buckets of hot water on it or run a hose.
    Might want to just blow the drain line out for the fun of it to... Would suck to have the drain plugg a week after you fixed the water leak.
    florida
    Works OK.
    That's what we use as well.
    Educational forums are open.
    Apr 2012
    Paper Street Soap Company
    Sooooo.....
    To get capacity of a pan in gallons change feet to inches and then multiply.....
    so 120'' ( 10 ' ) x 12'' x 6'' = 8,640
    Then you divide by 231 to get 37.4
    A gallon of water weighs 8.34 lbs
    so that pan full of ice weighed 308 pounds......
    damn thats heavy
    Nov 2008
    Altamont, IL
    Thumbs up
    HOT water melts ice the best...
    In GOD We Trust
    Wisconsin
    You have to fight through some bad days to earn the best days of your life.
    You can learn something from EVERYONE.
    Jun 2006
    Quote Originally Posted by BillDuffy View Post
    Electric heat guns on large coils don't work very well.Hot water is the ticket.
    Jan 2006
    Russellville TN and DeLand Fl
    Works OK.
    Just saw this process this past week, thought it was very inovative, no hose across the sales floor. Thinking outside the box!
    " If its Tourist Season, why cant we shoot them?"
