Results 1 to 7 of 7
Thread: R22 replacement
    Jun 2012
    az
    R22 replacement
    Is there a cheaper drop in replacement for R22 that will work in a walkin cooler?
    Sent from my SCH-I510 using Tapatalk 2
    Jul 2000
    Cuenca, Azuay, EC
    Quote Originally Posted by Phase8 View Post
    I'm opting for DuPont's Isceon MO99 (R438A). While no available replacement refrigerants are true drop-ins, MO99 comes very close as it requires no oil change and will work well for replacing R22 in existing low, medium and high temperature systems.
    It's cost is currently about 25% less than R22.
    Here's a good video from DuPont:
    http://www.youtube.com/watch?v=k2KP_rYBM5w
    May 2003
    Utah
    Quote Originally Posted by icemeister View Post
    MO99 is an easier retrofit as it doesn't require an oil change. If you've got a system where the compressor capacity is marginal, MO99 may not be the best choice. You will see a descrease in capacity using MO99 vs R-22.
    It's best to check with the compressor manufacturer and see what the compressor capacity is going to be in the application you're considering for a conversion and see if there will be sufficient capacity.
    R-407A, which requires POE oil, will be a better option capacity wise.
    Jun 2012
    az
    Quote Originally Posted by bunny View Post
    I have never done an oil change, is it difficult?
    Nah.
    Just pull the plug, let the oil drain all over the floor or roof, put the plug back in and add oil back in.
    May 2012
    Nah.
    May 2003
    Utah
    Quote Originally Posted by jmo90280 View Post
    And get a 10 lb bag of cat litter of the shelf....the manager won't mind.
