Results 1 to 7 of 7
    Jun 2009
    NYC
    Temperature control or Pressure control ?
    OK Guys,
    When it comes to med-temp refrigeration (matched or miss-matched units)
    You can control temperature by a temperature control or a pressure control. What's your choice of control when and why?
    I ask this question as my main concern is to prevent ice build-up on coils and eliminating defrost cycles/timers keeping products at a constant temperature.
    NE Alabama
    I like temp controls for most, but use pressure controls on R-404-A. 404 Is hard to control in medium temp situations as there is a slim margin of error, and cutoff is so high
    Jan 2010
    Constant Cut-in type for reach-in applications. Defrost the coil in off cycle.
    Pump down for w/i coolers with remote condenser.
    Oct 2011
    Hull
    When i have to replace an orit in a dual case , my boss whant i replace bye thermostat solenoid but i think controlled temp by pressure is better.
    What are we talking about specifically?
    A thermostat vs a pressurestat? I'll take a thermostat any day of the week.
    Now, if we're talking about using an ORI pressure regulator valve, I'll take that over either of the above.
    Jul 2000
    Guayaquil EC
    JP makes a good point about defining what we're discussing here.
    A lot depends upon the application. If your talking about a typical walk-in cooler, then I recommend thermostat & solenoid with pumpdown control and timeclock.
    If it's a self-contained service deli case with a gravity coil, I prefer a low pressure control with a timeclock.
    If you have any system with an outdoor remote condensing unit, that pretty much rules out a pressure control.
    Jun 2012
    Afghanistan
    Johnson Controls has a Digital A419 Temp. control that works great and is very accurate.
