Results 66 to 78 of 119
Thread: 51 Seconds to 500 Microns
06-13-2012, 12:41 AM #66
- Jul 2005
- Tulsa
- 258
check out this link ... lots of different size/configerations
http://www.centurytool.net/Flared_Tu...gs_s/37883.htm
06-16-2012, 09:03 AM #67
- Nov 2011
- Charleston, Wv.
- 792
man, I'm gonna have to finally invest in the high dollar hoses. bought a new set yesterday (4' with the 6" shorty's and ball valves. got them home. started testing with the micron gauge and pump......NONE of them would hold a deep vacuum. Even the 6" I had previously been using to attach the gauge to the CRT (which used to hold) is now leaking....frustrating.
06-16-2012, 09:18 AM #68
your not putting your micron gauge on one end of the hose and the other on the pump are you? What we are trying to accomplish is mass flow when we use big hoses.
Here is a test you can do..
Install one or 2 VCRT's to a 50 lb recovery cylinder and pull a vacuum on it. If your hoses are in good condition you will be able to pull a deep vacuum. I would say 200 microns... Isolate the VCRT's from the pump and hoses and your vacuum should hold if you have boiled everything off.
The other thing to remember, if those hoses you purchased are 1/4" you will be waiting awhile to achieve that vacuum.Gotta have the right tool for the job!
Where is all the stuff MADE IN THE USA?
"Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
06-16-2012, 09:51 AM #69
- Jan 2005
- Akron
- 790
06-16-2012, 04:04 PM #70
Well thanks. I throughly enjoyed it. Im glad I could share that with you. Finally HVAC is getting some good publicity!
On another note. Anyone try NRP 1/2" vacuum hoses? The price is similar to Appion but Appion is about a month lead time Im told. Thinking about going with NRP for convince. I use their regular hoses and they hold up well.
Is there any difference in the way Appion makes their hoses?Gotta have the right tool for the job!
06-16-2012, 05:18 PM #71
- May 2004
- 1,732
1/2 inch hoses seem too bulky to me. I'm thinking about going with 3/8 hoses. Anyone have any data comparing the pull down times between the two?
06-16-2012, 05:23 PM #72
- Jul 2005
- Tulsa
- 258
06-16-2012, 05:26 PM #73
- Jan 2005
- Akron
- 790
They make a good hose also, most of them are Goodyear GY5. The Appion hoses seem very supple for 1/2" hose. I am not sure however if they are GY5 or a proprietary hose. I do know that every hose is tested for performance and tightness under vacuum.
FYI the fittings make little to no difference on the hoses, in other words, a 1/2" hose with 3/8" fittings will flow the same as 1/2" hose with 1/2" fittings. It is the hose size itself that makes the difference. We will have the standard Appion 1/2" hose in stock as of Tuesday new week.JLB- Co Owner TruTech Tools Inc.
06-16-2012, 05:31 PM #74Gotta have the right tool for the job!
06-16-2012, 05:33 PM #75Gotta have the right tool for the job!
06-16-2012, 07:41 PM #76
Professional Member*
- Jan 2009
- ontario
- 48
06-16-2012, 10:28 PM #77
- Jan 2005
- Akron
- 790
06-17-2012, 11:53 AM #78
- Nov 2011
- Charleston, Wv.
- 792
CRT on the pump, then the 6" hose to the gauge.....I just wanted to check my 6" hose I had been using, as it didn't seem to be holding anymore.....getting to 200 wasn't the problem, staying there was the issue. as a stopgap, I ordered the YJ 45* female to female metal fitting to connect the gauge to the CRT. gonna have to save my pennies i guess.
