Results 1 to 13 of 15
Thread: Need feed back on my tool idea.
06-09-2012, 04:26 PM #1
- Mar 2012
- Sacramento
- 35
Hey guys
Let me know what u think of this tool ive come up with.
Its a safty jumper! It would have one clip one each side of wire, in the middle of the wire it would have a silver dollar size conponit wich has a digital screen to measure voltages, the kick is if u were to jump the wrong wires say like r and common it would trip setting off a red led light saving the fuse or transformer ect, then u would push the reset button and try it again,
I think this would be usefull for new guys as well as a vet. After the first trip it would pay for itself as well as save u time and money. What do u guys think let me know
06-09-2012, 05:11 PM #2
- May 2005
- Florida
- 572
It should read low voltage between r and common, why would anything trip?
If you're talking about trouble shooting low voltage shorts, I use a 3 amp circuit breaker instead of going through boxes of fuses.
I don't see the point of your "tool".
06-09-2012, 05:35 PM #3
I think the idea is to just have a simple troubleshooting tool for low voltage apps. Normally when I run into a low voltage situation, I just wire in my 75 VA step down transformer with a built in circuit breaker. That way, even if the original transformer is toasted, I've got an immediate emergency power supply and will put in a spade fuse after I fix the short. If the unit originally had a fuse protecting the circuit, then I just replace the fuse when done. Good thought process for the OP but I think we've got that one covered.
06-09-2012, 05:38 PM #4
- Apr 2012
- 41
Sounds like a " lil Popper" with a voltage readout.
06-09-2012, 07:15 PM #5
Professional Member*
- Dec 2010
- Chicago, IL
- 62
06-09-2012, 07:19 PM #6
Sounds like someone needs to learn to use a meter.
06-09-2012, 07:21 PM #7
06-09-2012, 07:30 PM #8
- Mar 2012
- Sacramento
- 35
Some systems are not protected by a fuse, i like the transformer idea. This is a tool more for entry level guys, i guess the point would be to prevent techs from shorting out conpoinents.
06-09-2012, 07:31 PM #9
06-09-2012, 07:34 PM #10
06-09-2012, 07:35 PM #11
Furlo, if we teach the entry level guys the right way to troubleshoot a circuit then they can excel much better .. Well i.m.o anyway. Hell the guy i mentioned in my previous post can jump out a stat btw lol. But he can't troubleshoot it
06-09-2012, 07:38 PM #12
- Mar 2012
- Sacramento
- 35
I would say there are alot of hvac guys who need to learn how to read a meter.
06-09-2012, 08:05 PM #13So let's not do anything to make that easier for them to ignore.
Originally Posted by Furlo
