Results 1 to 11 of 11
    Feb 2007
    Central NJ
    Confused Hydrogen produced from charging batteries
    this was a first for me this week: a township inspector gave a warning to a company that refurbishes old game machines telling them that their warehouse may not have enough ventilation for two battery operated fork lifts. the warehouse was of significant size, both forklifts were at each end of the warehouse separated by a concrete wall. both had multiple exhaust fans at the roof (at least 18-20ft high). did some research online about hydrogen produced from charging batteries but most of the ventilation warnings revolved around battery producing factories and the like.
    so has anyone else come across this issue with local governments? does duct need to be installed with separate exhaust fans for these two forklifts?
    You have to pay your due's before you pay the rent!
    Jun 2006
    New Jersey
    Quote Originally Posted by n-e-w Jerz! View Post
    Not sure what the code is........but we always had to install a exhaust fans above the charging stations. Height above stations and ventilation rates are stipulated. Just don't remember what the numbers are.
    Saint Joseph, MI
    For two electric forklifts? ON opposite ends of a large warehouse? Doesn't seem nessesary to me. Only if it was a smaller room or confined area.
    It may depend on what battery they have. I think the newer maintenance free "gell" and AGM batteries are completely sealed unlike the older lead acid that needed the water level checked and topped off periodically.
    Feb 2007
    Central NJ
    my thoughts exactly. i mean, how many ppm are we talking about once it dissipates into the surrounding area? there are no solvents or open flames near the charging space. again, i saw pictures of roofs blown off of factories due to this phenomenon, but no mention of it happening with singular devices.
    Jun 2012
    Northern NV
    Heck, just start using a forklift that burns LP.....;-)
    I think the inspector is looking for problems that do not exist. Perhaps his wife was mistreating him today?
    Ohio
    It's not about the forklifts them selves but about (the most likely) one charging station for the two lifts.
    Around here code says we need to have hydrogen alarms and ventilation.
    Jun 2006
    Charlotte, NC area
    Your township inspector has probably been to a seminar or read an article on Hydrogen.
    Not sure what code you are under there, but the 2009 IMC section 502.4 indicates the hydrogen limit must be 1.0% or less based on room volume or you must ventilate at 1.0 CFM/SF.
    Given that your warehouse is large and you only have 2 batteries it’s obvious you’re not going to get to 1%, but you are going to have to convince the inspector.
    The fork truck manufacturer can give you the hydrogen production rate for the size batteries and you can assume some infiltration rate maybe .01 CFM/SF or 10CFM per dock door or whatever and show that it is much higher than the Hydrogen rate. Hopefully this will satisfy him.
    Jan 2013
    My company manufacturers hydrogen/freon detection devices so I get this question a lot.
    It is unlikely that the forklift area would ever be able to accumulate a high level of hydrogen because of the room size and likely the ventilation or even natural ventilation system.
    However, this web site in the UK actually provides you with the formula for calculating potential off-gassing of battery strings so you can easily demonstrate to an overly paranoid, uninformed inspector that a detection device is not required.
    http://www.cisco-inc.com/battery/hydrocon/
    Avon Lake, Ohio
    The gas is actually hydrogen sulfide, a toxic, poisoness and flammable gas. It has set off many a carbon monoxide detector because it does react with their sensors. Not CO but still dangerous. I sold Hydrogen Sulfide Alarms to airport control towers that have quite a few batteries for power back-up.
    Large warehouse, only two batteries, shouldn't be a concern. Why is it that no one is concerned the lift trucks put out 10,000ppm of CO? Do they have any monitors for that?
    captain CO
    Caledonia WI
    Are you sure he wasn't just looking to get his palm greased?
    Aug 2012
    Quote Originally Posted by Juan Madera View Post
    More like his boyfriend.
    He read one too many articles in his engineering magazine.
    It's not if your doing it right it's whether your doing the right thing that is important.
