Results 1 to 11 of 11
    Question regarding Lennox Icomfort WiFi Stat.
    Does anyone know the compatibility of the Lennox Icomfort WIFI stat? I currently have a Lennox XC21 with a variable speed handler and a Lennox Harmony III zoning system. Thanks!
    burlington county n.j.
    rumor has it there will be an interface to allow it to work with standard systems......... time will tell.
    carthage ms
    the module to make it compatible with non communicating systems will be released in the 4th quarter of the year, the xc units and the a/h have been communicating systems for a while now, how old is your set up sandman?
    The 2008 NATE TOP TECH!!!!!
    First, thanks for the replies. The system is 4 years old. Two zones only.
    does not matter if equipment is i comfort equipped, thermostat will have to interact with Harmony control.
    many of the i comfort features will be disabled with this set up.
    Quote Originally Posted by t527ed View Post
    How do I know if my system is Icomfort equipped? I'm a little confused.
    Thanks!
    Quote Originally Posted by sandman512 View Post
    Thanks!
    would have to look at the boards in the furnace and a/c.
    the fact that you're using a Harmony zoning system makes it a mute point anyway. thermostat only "talks" to the zoning panel and most features of the i comfort will be disabled.
    Paul12644
    Your post has been deleted.
    Rather then start a new thread, I thought I would add to this one.
    Still trying to determine if the Icomfort WiFi stat will work with my setup.
    XC 21
    CBX32MV
    Harmony III Zoning.
    Thanks!
    latest word is interface module will be out in 4th quarter 2012.......
    who knows exactly when it will happen.
    as of now it is not compatible with the Harmony board.
    T527ed,
    I guess I need the interface module due to my Harmony board?
    Thanks.
