Page 1 of 25 1234567811 ... LastLast
Results 1 to 13 of 313
    Ohio
    Pulling a vacuum....PROPERLY...
    This is a little thread to show MY way of pulling a proper vacuum on a system and just how quickly it can be done.
    This was an evap coil change out I did today. Lineset was disconnected in the basement for about an hour while I did sheet metal. The lineset was 30 feet long and I pumped this system down, so when the vacuum was pulled it was pulled on the lineset and evap coil only...
    The total job took 2 1/2 hours.....here's the pics....
    (sorry about some of the quality...my camera is not the best)
    Pic. 1 - My pump set up....no manifolds needed...why would you want to pull a vacuum on them anyway??
    Pic. 2 - The pump hooked to the unit....I use core removal tools to get the cores out of the way and also have a place ON THE UNIT to hook up my micron gauge. Why would you want to measure the vacuum anywhere else??
    [IMG]http://i514.photobucket.com/albums/t...8124/Pump1.jpg[/IMG]
    Pic.3 - Just before turning the pump on for the first pull....notice the time 2:09 pm and the gauge starts at 25,000 microns.
    [IMG]http://i514.photobucket.com/albums/t...8124/Start.jpg[/IMG]
    Pic 4. - 7 minutes and my gauge is at 200 microns.
    [IMG]http://i514.photobucket.com/albums/t...24/200at10.jpg[/IMG]
    Now I break this vacuum with about 2 psi of nitrogen and start the process all over again....
    Pic. 5 - This is the second pull with the vacuum and I am now at 160 microns and have been at it for just 11 minutes...
    [IMG]http://i514.photobucket.com/albums/t...24/1stPull.jpg[/IMG]
    Pic 6 - Before the last pull, I break with nitorgen and put the cores back into the system with it under a possitive pressure so not to draw moisture into the system...I only need one hose to pull and my micron gauge at this point. Here is the set up....
    [IMG]http://i514.photobucket.com/albums/t.../FinalPump.jpg[/IMG]
    Pic. 7 - After ONLY 30 minutes I have pulled 3 vacuums on this system and after being off the pump now for 5 minutes.....here is my final reading....holding steady with no rise what so ever...
    [IMG]http://i514.photobucket.com/albums/t...4/Finished.jpg[/IMG]
    This thread is not to brag or to boast....I am not an engineer nor do I claim to be the best tech in the world...but proper procedures and proper tools will make all the difference in the world!!
    I need a new signature.....
    AMEN to that!!!
    i still use two hoses on the last pull well i overkill everything anyways lol
    Ohio
    AMEN to that!!!
    So if you are using 2 hoses on the final pull...where are you hooking the micron gauge?? I was doing the final pull with my core remover still hooked up but got paranoid about allowing in air and moisture while trying to put in that last core under a vacuum??
    lol it's a trane washed world around here, on the HP's i use the discharge port
    i rarely pump a system down too.
    worried about letting air in when disconnecting your micrin gauge, you put refer in while it is still atached to the system i sure don't
    Anytown USA
    Quote Originally Posted by I_bend_metal View Post
    yeah your not supposed to put cores in under a vacuum.
    Why even pull the cores on such a small system?
    Jul 2001
    Anderson,SC
    Why can't you put the core back in while in a vacuum?
    I do it on each vacuum, I use the field service valve tool.
    STUD
    Ohio
    Quote Originally Posted by HVAC/Stud View Post
    STUD
    Because under a vacuum you are going to allow outside air into the system...connect your micron gauge to the core remover and watch it when you put the core back in....it's just a little bit but your microns will rise dramatically...
    Ohio
    Quote Originally Posted by y7turbo View Post
    Small?? That's an average size system for this area....I do resi only....and pulling cores makes things go that much faster....IMHO
    Oct 2008
    So Cal
    Nicely Done
    Atlanta, GA
    Fixed the images.
    Jun 2005
    South Jersey
    From what I learned in here recently, it's impossible to pull a proper vacuum unless you are an engineer.
    Ohio
    Quote Originally Posted by bustawrench1 View Post
    I don't think he has seen this thread yet....I linked the other one to this one...LOL
    Jun 2007
    Greenville,North Carolina
    By the way,good set-up/procedure.But you are not doing it right regardless because your not an know-it-all engineer.
    Look to the past to learn;look forward to live.
    Coach Dean E. Smith
Tags for this Thread
