Results 1 to 13 of 18
    Nov 2008
    southeast U.S.A.
    RTAA EXV test failure
    Greetings,
    Having some trouble with a RTAA 80 ton. I replaced both EXVs and the EXV board. I started getting nusiance trips "EXV failure" on both circuits every now and then. But now, circuit 2 will not run at all. I can run the diognostic and the valve drives both ways. I understand that the EXV board sends out a pulse to test the windings before a startup. Has anybody else had simular faults?
    Thanks,
    eric
    Not in Iran
    If u changed that already and that has not fixed ,. New wiring, just saying ,
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    Dec 2009
    Southern US
    Didn't we ask this a few days ago! More info! Amps, pressures (verified). At start up and shut downs, trips! Entering and leaving water temps.
    Just more info!
    I'm good at making things cold...You can ask my first two wives!
    The Hot South
    Double post?
    Ohio
    You need your pro status. Trane EXV's are covered in depth in the pro chiller section.
    Apr 2012
    Paper Street Soap Company
    So you had one go out and need to replace the board, both cables and both valves because they don't carry the old valves anymore.
    I'll be glad when these RTAA's are just a bad whiney thermistor eating memory.
    Is it possible the initial diagnoses was wrong and you're dealing with the same issue but with two new valves and a board ?
  7. Likes Fathma liked this post
  8. #7
    Nov 2008
    southeast U.S.A.
    Another tech condemed the old EXVs. They were now obsolete, so when I replaced the EXVs, I also replaced the board (The EXV motor windings were completly different). I started receiving faults right off the bat. But after double checking the connections and running the valves through a diagnostic, they seemed to work OK. Then one the circuits, usually #2, would shut down on the EXV failure fault, but clear and restart. Now #2 will not pass the start up electical test no matter what I do. It really bothers me that the valve works perfectly but fails the little pulse test on startup.
  9. #8
    Apr 2012
    So the machine is inoperable ? Seems you still have an issue.
  10. #9
    Ohio
    You did run new EXV wiring right?
  11. #10
    Not in Iran
    Yo
    Bite the bullitt and call the big dogs in
    If u want my
  12. #11
    Quote Originally Posted by zoofer View Post
    Greetings,
    Thanks,
    eric
    is this a remote barrel?
  13. #12
    The Hot South
    Did you run new wiring or change the plugs??? The pinout is different.
  14. #13
    Oct 2010
    Greece
    Hi,
    Just an info I want to share about new EXVs.
    If you remove the EXV cable from module while in operation you have good chances to burn out module. Maybe your new module is defective!!
    Check according to PART-SVN118B-EN August 2009.
    CV
  15. Likes Fathma liked this post
