Page 4 of 4 FirstFirst 1234
Results 40 to 46 of 46
  1. #40
    Quote Originally Posted by hamons View Post
    The company never would do a Manual J - but after replacign every part in the system -- they decided to try a bigger unit.
    Sure, why not? And if that doesn't work maybe they'll tell you that you need new windows. Or more insulation in the ceiling. Or maybe a half-ton bigger unit.
    Hopefully these hacks don't charge you anything while you are getting.. uh, experimented on.
  2. #41
    Madison, WI/Cape Coral, FL
    As the a/c ages, cooling capacity will decrease. That makes this undercooling problem bigger with a very 1% moisture removing on the low end. The sad part of this story is that this undersized a/c is unable to maintain <50%RH during wet cool weather. Size for the extreme. Pulling the temp down after tstat set-up and being able to maintain desired temps with friends is big. If you live in a green grass climate, include supplemental dehumidification. Dehumidification is part of the package to deal will moisture from proper fresh air ventilation and occupants during cool wet weather. Everyone will be more satisfied and healthy. You overal operating cost will be lower and you home healthier. Regards TB
  3. #42
    Is the new unit, a 1/2 or full ton bigger then you old unit.
  4. #43
    Sorry, But Theres Not Enough Info.
  5. #44
    Oct 2005
    THe unit is now 1/2 ton bigger. From 2.5 - 3 ton
  6. #45
    Are you getting better air flow with the 3 ton unit.
  7. #46
    May 2008
    You should have called another HVAC contractor that would do a manual J and d on your home. Sounds like the contractor you are using doesn't know what he is doing or care. You shouldn't have to keep upgrading your system before he finds the right one.
