Results 14 to 19 of 19
    May 2011
    s.e. pennsylvania
    I have to cast my vote for the h10, if you know how to use it it can do some amazing stuff
    Jun 2012
    Tenn
    "man ... really on a 200 ton system..... thats a lot of bubbles... lol"
    Even when I do use a leak detector, I can only get a general idea where the leak is. Soap and water is still going to have to tell me where the leak is. At the company that I work at, none of the techs ever use leak detectors, either. The 400 ton units that I worked on in the Navy were low pressure chillers. An R-410A will blow much better bubbles than that R-114 from the same size leak.
    California
    Quote Originally Posted by sprmktrefertech View Post
    does it make a difference, between the Yokogawa ,Bacharach, or Mars...
    does it really matter?
    I have the Bacharach and Mars units. there is no difference between them other than the name on the label.
    Jul 2005
    Tulsa
    Hey, all H10 pm fans....does it make a difference, between the Yokogawa ,Bacharach, or Mars...
    does it really matter?I found the yokagawa cheaper.
    I have the 110v model, but,only use for self contained stuff....
    could be wrong, but it's my understanding yokogawa makes the H10 for several companies, who turns around and relabels it. my H10 is labeled GE, but is made by yokogawa.
    patents have ran out long ago. so it's possible for other mfg to make identical unit.
    Jun 2012
    Afghanistan
    120 volt H10 is the only way to go.
    I have the D-Tek select great leak detecter don't care for the rechargeable batteries should have been set up to use "2" D-cell batteries like their cheaper heated diode type leak detecter.
Tags for this Thread
