    tidewater, va
    Hey guys,
    A) Anyone know the torque value for the seal coverplate bolts?
    B)What is acceptable leak rate?
    and C)Do you guys pull these things out with and pre-load them with threaded rod? (that is, are there female threads in the main body to accept say 1/4-20 rod to pull it out evenly like on a York Centrifugal)
    Thanks 404
    Jul 2000
    Dallas,Texas
    http://www.xpedio.carrier.com/idc/gr.../5f,h-23si.pdf
    55-60 lbs/ft
    The seal plate will bump off when the bolts are out.
    The seal is a bellows type that is replaced as an assembly.
    You will not need a puller for the seal. Bearing yes.
    tidewater, va
    wolf,
    thanks for the answer and the link.
    r404a
    Jul 2000
    Dallas,Texas
    No problem.
    Cape Cod
    5H
    After Seal is installed and some run time you should not have a leak. You will not need a puller but you will have a heck of a time pulling the seal out.
