Results 1 to 13 of 17
    We have a new Goodman furnace,an older Fedders central air unit, and a Honeywell thermostat. Our air conditioning unit--both compressor and fan will not stop running once the thermostat reaches the desired temperature. We usually keep the t'stat set on 72. The fan is set to Auto. This morning when I got up the room temperature was 62. The unit had run nonstop all night. The only way we can get the unit to stop is to turn the switch to Off on the t'stat. Any ideas?
    Jan 2005
    something is wrong with your thermostat, wires, circuit board, or contactor
    you should call a service tech
    Dec 2000
    NW Ohio
    Is it a round honeywell?
    Common problem, have the stat replaced.
    Jun 2006
    100% agreed have stat replaced
    Apr 2003
    arizona
    wanna buy a t-stat LOL
    I doubt it's a wire short if it stops when you switch it to off. Sounds like you need a new thermostat. I wouldn't do it yourself, have your contractor come out and swap it, and test everything at the same time to make sure nothing else is bad.
    "Why must I lose to this idiot?!"
    Chess Master Aron Nimzovich, after jumping on the table...
    I don't know
    If you don't have a heatpump or anything which requires more than four wires, replacing a t-stat can be a DIY task. (I know I’ll get flamed for this)
    I'm not going to post any DIY instructions of obvious reasons, but whatever you do, turn the power off first to avoid shorting anything out.
    It's your choice; many members here go overboard and think that a homeowner shouldn't even change a filter if it happens to be in the blower compartment.
    Indiana
    amd is right but you still may want to call a service tech out just to make sure ther is'nt any other problems.
    Jul 2005
    Orange County, NY
    This is the most intelligent answer and best advice here. I suggest you follow it.
    Core
    I recently changed out my thermostat. Simple 4-wire project. All electic AC/Heat. But, I knew beyond doubt that my problem was the thermostat. Had I not known that, I would have called my HVAC company.
    good luck,
    jdb
    Florida
    Many members here think of homeowners safety first, which is why I wouldn't advise changing a filter in a compartment that contains line voltage.Alot of homeowners don't have a clue as to what can hurt them. Remember this.
    Florida
    good luck,
    jdb
    Here's a classic example. JDB was successful. That's good. What if that t-stat was a old line voltage one, and homeowner doesn't know the difference. Homeowner badly hurt/dead, great internet advise to blame.
    Smokin 68,
    I understand the resistance to DIY information on this site. When I changed my stat, I researched it and got advice from another site, and frankly, I was surprised that such information and willingness to help was available given understandable liability concerns. But, the final responsibility for these kinds of decisions are with us, homeowners. If something bad happens, we are to blame, not you or any internet advice. I know that not everyone would see it that way.
    If I was in your shoes, I wouldn't give DIY advice either.
    jdb
