If you're not joking, you should turn it off and call a contractor to start over again on Monday.
Installed a 2 ton air conditioner to my furnace but I have one question. The low and high side pressures are reading high, the high-side is around 450 psi and the low-side around 250 psi. wondering if the system could be over-charged. It has enough R22 for 20 ft of line-set I used 23 ft of lin-set. There is also a hiss coming from the inlet of the evaporator, has a fixed orifice.
TROLL WARNING!!!Originally posted by shwan5000
Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
"It's what you learn after you know it all that counts." ~ John Wooden
"When the teachers become unteachable we're all in trouble" ~ Mr. Bill
"Remember "Pro" is only a name, it's not always a mindset determined to do everything correctly" ~ Mr. Bill
what the &%$#@?
installed your own system huh? It's not running for long.
Sounds perfect,
what?
Take a picture of yourself with those gauges in the picture, and post it in the wall of shame!!!!!!!!
easy fellows easy on em
