Results 1 to 7 of 7
    Installed a 2 ton air conditioner to my furnace but I have one question. The low and high side pressures are reading high, the high-side is around 450 psi and the low-side around 250 psi. wondering if the system could be over-charged. It has enough R22 for 20 ft of line-set I used 23 ft of lin-set. There is also a hiss coming from the inlet of the evaporator, has a fixed orifice.
    Jun 2006
    Michigan
    If you're not joking, you should turn it off and call a contractor to start over again on Monday.
    Houston,Tx.
    TROLL WARNING!!!
    “I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
    The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
    No Guns…No Freedom…Know Guns…Know Freedom.
    L.I.Newyork
    what the &%$#@?
    Florida
    installed your own system huh? It's not running for long.
    Southern CT
    Sounds perfect,
    what?
    Take a picture of yourself with those gauges in the picture, and post it in the wall of shame!!!!!!!!
    Jan 2005
    easy fellows easy on em
