    Central California
    Can someone tell me why it is not pheasable to have a residential solar refrigeration system? Thanks
    because...
    ...the installed cost of a photovoltaic electric system is on the order of $8-$10 per Watt and AC (which, I assume is what you mean by "residential refrigeration") uses thousands of Watts while running.
    You do the math...
    Jun 2006
    Anything is possible with the right amount of $$$ applied, but I know a standard joke in the solar community is that when the salesman starts talking about solar AC you should be running for the hills.
    That said I have given the idea some thought, and I see some possible ideas worth exploring, if I just had an investor ...
    Nov 2005
    Northern VA
    Not enough BTUs of cooling for the amount of solar heat you need to take in for an adsorption system, or the amount of PV panels you would need to run enough of a DX system. (To be more specific, it's *possible* but the first cost would be *insane*..)
    Solar is great in some climates for hot water though.
Plumbing Talks | Contractor Magazine
Forums | Electrical Construction & Maintenance (EC&M) Magazine
Comfortech365 Virtual Event
