Results 14 to 26 of 27
    Float'N Vally, MS
    I have noticed that "most" of the high end scroll systems now come with a "start kit".
    Life is too short, Behappy!
    TFMM
    Nov 2000
    Eastern PA
    Originally posted by riderman
    I was taught that a hard start kit was a bandaid for worn compressors essentially on their way out.
    You were taught wrong.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Feb 2005
    Toms River, NJ
    You need a hard start if:
    1. Hard shut off TXV
    2. Long Lineset
    3. Low ambient conditions
    4. Voltage problems
    Dave in NJ
    2. Long Lineset
    4. Voltage problems
    Dave in NJ
    Scrolls start with out hard start kits even against non bleed TXV's.
    Apr 2004
    The truth of the matter is, a start kit in most scroll applications is a bullet point or a selling feature. Its something that can be added to a spec to make the use of lower end equipment require adding to. Now, if you are going to run these obnociously long linesets, it's something you might add to a scroll, but in fairness, its not required often at all. In reality, the money would be better spent on LPS, HPS, CCH, and even Driers.
    Yes, some recips with non-bleed TXV's need start componants, but even the Benchmark Recip, has built in features that can overcome that need.
    San Dimas, CA
    Scroll..capacitors
    Yes, residential scroll compressors do have capacitors in which specifications are found in Copeland Electrical Handbook 2005-2006 Edition.
    [Edited by smithone on 07-23-2006 at 04:02 PM]
    start caps on nall trane and am standard compressors. scrollla nd recip
    as per mfg recommendation. all scrolls and receips should have a hard start kit installed. scrolls and receps are equiped with non equalizing txvsand a start cap is therefore recommended on both. checkvalve in compressor prevents bleeding back and balancing pressure on the scrolls.
    Scroll compressors have more internal mechanical friction to overcome on startup, so the inrush current tends to be higher than the same size recip, which in a changout situation, can result in more noticeable light dimming in the house when the compressor starts. This is a common complaint in some areas.
    A start kit on a scroll compressor reduces the length of time the motor pulls LRA, which reduces the lights dimming in the house when the compressor starts.
    Some manufacturers also require a start kit for scroll compressor equipped systems that are used for low ambient cooling.
    Rheem's 13 SEER units come factory with start kit. RAND/RPNE. Looking at A-S 13 SEER, only the 3 ton and 5 ton have scrolls. The 3 ton does not have a kit, the 5 ton does. We had some complaints about lights dimming with A-S scrolls in the past and the distributor would give us a free start kit in those cases.
    Atlanta GA area
    Hey Mark,
    I was in a 'counter conversation' with another tech on this topic a while back. They suggested that a start kit on a scroll would increase the energy efficiency. Seemed to me that if it lowered the light dimming, it would also lower the KWH's used... Any thoughts? THX in advance!
    GA-HVAC-Tech
    Quote Originally Posted by ga-hvac-tech View Post
    Hey Mark,
    Well, the start kit doesn't lower the peak LRA, but it does shorten the time the motor is at LRA, so I would have to agree that it does improve the efficiency, however slightly.
    And before someone jumps in and says that a start kit lowers the peak LRA of the motor on startup, and points to their amp meter readings, your meter doesn't have a fast enough response time to show you the true peak amperage on startup. You get a lower reading because it pulls LRA for less time, so the amperage has dropped off more before your meter displays anything.
    Dec 2006
    Madison WI
    Do a search on screen name payson.
    He has a link to a video of the amp draw of a compressor with and without hard start kit.
    And of different start kits.
