Results 1 to 13 of 27
    Jul 2003
    On a txv system with a recip. compressor do you need a start capacitor?
    On a scroll compressor with a txv do you need a start capacitor?
    Yes and yes... kick start
    Scrolls don't need a start cap.
    But it doesn't hurt if they have one.
    beenthere is right
    Jun 2006
    Do I have this confused, mostly I hear about using a "hard start kit" with a txv, and all compressors us a combined run/start cap don't they?
    Philadelphia, PA
    txv + hard start kit = mostly, but not always
    all compressor use combined run/start cap - nope
    burlington county n.j.
    have never put start kit on scroll compressor. 99.99% of my units are lennox scroll units with txv. have been using scroll units since they came out around 1990.
    The refrigerant does not equalize when a reed compressor is matched with a txv, therefor the compressor starts under a load... ya need a kick
    I was was wrong about the scroll. I should have yep and nope.
    Houston,Tx.
    Ruud and Rheem puts one on "every" one of there 14 seer units must be doing it for some reason, or it could be maybe they just like to spend the extra money, yea thats it.
    have never seen or put one on a lennox unit. maybe they are using different txv's???? as i said i have been installing lennox units with scrolls since 1990. to date i may have had 6 compressor failures.
    I think I undestand the reason for a "hard start kit" for 14 SEER units with a TX valve based on coments from here.
    I was taught that a hard start kit was a bandaid for worn compressors essentially on their way out.
    Why arent NEW high SEER units designed with a cap or compressor to handle the designed start up load?
    Old compressor technology?
    Just wondering...
    Recip compressors for A/C, H/P applications are made with low torque starting motors, Even with a TXV that equalizes most of them need a start cap.
    Start, run caps are seperate things. Duel caps are run caps for both the compressor and fan.
    Jul 2003
    thanks for the comments
