Results 14 to 20 of 20
Thread: Capacitor question
06-05-2012, 07:45 PM #14
- Feb 2007
- Central NJ
- 374
any dual cap should be replaced if one side is bad. if you have to get one for each fan/compressor they need to share a common. it almost sounds like the compressor cap side was week or went dead and it opened on thermal overload or the fan stopped running on a call for cooling causing thermal overload. high amps during operation will expose potential weak/dead cap(s).
You have to pay your due's before you pay the rent!
06-05-2012, 08:11 PM #15
Essentially, a "run" cap is a kind of a start cap, and we call it a "run" because it STAYS in the circuit while the unit RUNs. It is designed to stay in the circuit according to the design of the start windings, and the fact that it is oil filled, and can take the heat.
A START cap is only in the circuit while the motor STARTS. It is removed using a relay of some type. It is a dry cap, and cannot take the heat of staying in the circuit like the run cap can.
Hope that helps.
My bet is united sold the OP a defective replacement cap.[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
06-05-2012, 08:22 PM #16
06-05-2012, 08:37 PM #17
06-05-2012, 08:41 PM #18
06-05-2012, 08:42 PM #19
Back to the United on the Black Horse Pike in Mt. Ephraim, I presume....
2 Tim 3:16-17
AOP Forum Rules:
06-05-2012, 08:53 PM #20
That is exactly where I got the first one. The one that is in there now is an oem from Pierce Phelps. Unit has been running for a while now just did not know why it didn't with the first one. I am sure your right about the cap being bad like I said earlier I will have to find it at the bottom of my truck and test it under load.
You need to put the phone down and get back to work!
