Results 1 to 6 of 6
    ice stopping switch
    Does anyone know where I can get the ice stopping switch ?
    This is a large ice box (trailer) with 2 Artic Temp Ice machine. I just wanna install 2 switches (float switch) to turn them off when the ice is full.
    I rather get the complete set than building me one with x-former, AC to DC converter, float switch, and DC relay.
    Appreciate it if you can point me to the right place.
    Jun 2012
    Northern NV
    Use a remote bulb thermostat instead. When ice contacts the bulb at 32F, it opens a contact and stops ice production.
    Quote Originally Posted by Juan Madera View Post
    The owner had bad experience with it. Besides, it is not too accurate. He had used it many tries. But not too impress.
    Thanks though
    Jun 2012
    Northern NV
    How about a photo switch? (like on garage door) They do need cleaning occasionally...
    A "float" switch is not viable. Ice cubes are not water. Ice just buries the float.
    Just brainstorming, but think rubber bladder attached to a pressure switch from a inducer proving application on a furnace. Ice buries the balloon, trips switch. Remove ice, pressure drops and turns on ice making?
    Oct 2011
    Hull
    Try the eaton photoelectric sensor. Never have problem with that
    NE Alabama
    Manitowoc uses a magnetic switch in the water curtain. When curtain is held open by ice switch opens and stops machine. Hoshizaki uses a proximity switch. When bin is full ice moves a paddle which opens switch stopping ice machine. Just a couple of methods not involving temperature.
