Results 14 to 26 of 41
06-08-2012, 08:56 PM #14[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
06-08-2012, 09:57 PM #15
06-09-2012, 07:10 AM #16[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
AOP Forum Rules:
06-09-2012, 10:49 AM #17
06-09-2012, 02:18 PM #18[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
AOP Forum Rules:
06-09-2012, 02:26 PM #19
yep. most oem start relays go out due to very short power outages. The power flickers, there is no delay on fridges that dont have the microprocessor board, so the unit tries to start back up...over and over and over. Sometimes it takes 10 minutes for the pressures to equalize in a domestic fridge and the whole time the unit is trying to start up under pressure. It eventually overheats and breaks the little disc inside the oem relay.
06-10-2012, 04:20 AM #20
Okay, I have definitely learned something. Thank you.
Sent from my SCH-I510 using Tapatalk 2
06-12-2012, 09:06 PM #21
Professional Member*
- Oct 2009
- Raleigh, NC
- 455
A couple of things: A 3 in 1 (like a Supco) IS a PTC start device. Also, the "klixon" used with standard starting components is an overload, not a relay. It intentionally overheats when there is a high amp draw across it and opens the circuit until it cools down. It does not provide any measurable thermal protection for the compressor itself. Thermally protected devices have switches mounted within the motor windings.
There is nothing better than the OEM current or potential relay. I use 3 in 1's fairly often, but I will replace all starting components with OEM in most circumstances.
06-12-2012, 09:10 PM #22
- Oct 2009
- Raleigh, NC
- 455
Also, I have never heard of an "induction start, induction run" motor.
06-12-2012, 09:21 PM #23
- Jun 2012
- Tenn
- 97
"My question is it normal for ref tech to use a hard start instead of OEM relay to take out start winding."
The company that I work for has that for a policy. Personally, I would only use it for the last ditch troubleshoot before condemning the compressor, but, I work for a company with that policy, and it is a viable option as it includes thermal overload, relay and start cap.
06-13-2012, 06:55 PM #24[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
AOP Forum Rules:
06-13-2012, 06:59 PM #25
The white piece that goes on common is an overload. It will say klixon. The other piece, with the disc in it, is the relay. It is usually black or brown, sometimes white on certain models.
http://www.partselect.com/PS2004058-...-Relay-Kit.htm
06-13-2012, 07:25 PM #26[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
AOP Forum Rules:
