Results 1 to 13 of 41
06-05-2012, 03:57 PM #1
Professional Member*
- Jul 2001
- Anderson,SC
- 884
Residential HVAC tech has question
I sometimes repair domestic refrigerators. The last one had a defective motor start relay. It is a klixon, the compressor motor is a induction start and induction run. No capacitors.
I went to an parts house and the counter help said we recomend to put a start capacitor in place of the relay. He said thats what all the appliance techs do, it's cheaper.
I like to allways go back with OEM parts. I would think the start winding maybe damaged by the start cap. I know the start winding are dropped out by the relay, and the start cap has a relay.
What do the refer techs say? Is it y'all policy to skip the relay and just put in a start cap?
Thanks,
STUD
06-05-2012, 04:20 PM #2
Some appliance motors use a centrifugal switch to drop out the start winding.
That said is is it any different putting a start relay on that motor than putting a hard start on a compressor ?
06-05-2012, 04:32 PM #3
- Jul 2001
- Anderson,SC
- 884
I would think a PSC motor would be built with stronger windings and can handle a hard start.
A small HP IS/IR motor would not be built to handle a start cap.
The key is to drop out the start winding. My question is it normal for ref tech to use a hard start instead of OEM relay to take out start winding.
STUD
06-05-2012, 06:00 PM #4
Back when I did work on res. refrigerators, I would normally use a Supco RO-81 or 41 to replace the start components. Other options were a IC-G1 relay and a RSC-10 (when the others wouldn't work).
Don't remember ever using oem relays.
06-05-2012, 06:01 PM #5
When my PTCR decided to break into several small pieces on my home unit, I installed a 3 in 1, and it has worked great ever since.
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
06-05-2012, 07:35 PM #6
06-06-2012, 05:12 PM #7
- Jul 2001
- Anderson,SC
- 884
I don't put a start cap in when all you need is a relay.
Seems like a waste of a start cap.
I deal mostly with PSC motors, not induction start and induction run. Sometimes a shaded pole.
I was just wondering what refrigeration pro's do when relays fail.
STUD
06-06-2012, 08:46 PM #8[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
AOP Forum Rules:
06-06-2012, 10:05 PM #9
06-07-2012, 10:18 AM #10
- Jul 2001
- Anderson,SC
- 884
Do you leave the external overload on. The start cap doesn't include a over temp safety. Its dropped out of the system.
If you remove O/L and install the start cap, where is your compress safety?
STUD
06-07-2012, 11:50 AM #11
06-07-2012, 01:04 PM #12[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
AOP Forum Rules:
06-08-2012, 06:43 PM #13
Can never go wrong with oem.
Sent from my SCH-I510 using Tapatalk 2
