    Can someone tell me whats the way to determine what to set the timer to? Maybe 90 minutes in the deep south, 30 minutes in the cold north and 60 minutes in between (like were I am in Baltimore area). Could I get a responses from from a few of you in different areas on what you set it to. Thanks
    try 60 minutes. then watch to see that works well
    it depends on temperture and humidity in your area.
    Baltimore might need 30 min.,but you will have to see for youself
    Heat Pump Defrost Timer Question
    Its my daughters unit, what do I tell her to look for? thanks
    Apr 2003
    California
    you tell her to have a preseason heat tune up done with attention and explanation to this detail. A tech in your area will know what it should be set at basically. good luck
    Glad to see another Redskin fan on this board!
