Results 1 to 2 of 2
    Aug 2005
    outdoor unit power coming low voltage also coming when i put jumper RY unit run then i changed thermostate but same problem
    how low is the votage coming in, it sounds like if you jump ry your unit should start, but if it doesn't start w/out the jumper it sounds like it may not be wired properly or you have a component stopping the voltage from getting to y. Check your pressure switches, time delay, etc.
