    Jun 2012
    Square hole expose heat exchanger on furnace
    Hello..
    Working on a 105k btu furnace, noticed a square hole cut into the heat exchanger. Remove square cover and a man made hole was exposing the heat exchanger. Is this normal? Is this some kind of repair?
    NE Alabama
    Sounds like a hole for inspection or repair and as long as it's tight it no biggie
    Jun 2012
    The hole measures 12x12 . I was told the heater is oversized and the ductwork is only 8x8,
    Someone cut the hole to allow the heat exchanger to cool down. Is this possible?
