    I know the condenser fan and coil on a refrigerator get dirty and need occasional cleaning. It's looks like it would be simple to remove a panel in the back of the freezer and check the evaporator. Just wondering if it's worth the effort.
    Nov 2005
    Northern VA
    On some models spills can drip onto the evap and make a sticky mess back there.. might as well check it if it's easy to get to.
    Jan 2006
    I wouldnt less there was a promblem with smell or temp or drain promblem,them things are time consuming.
    There are three signs of old age.
    The first is your loss of memory,
    the other two I forget.
    Jan 2001
    Most evaporators on fridges I run across are clean..... where I find most problems are in the condenser fan area....
    Clean under the fridge....clean the fan and condenser...even if its a once a year cleaning....
