    Dec 2011
    louisiana
    old RRU30 oil change
    How do you guys (if you can remember that far back) change the oil in the old blue RRTI RRU30 recovery unit? There is only the 3/8 oil drain to fill through, kinda small for any funnel I have.
    Greg
    Oct 2011
    Arkansas
    I'd pull a vacuum on the inlet port (Ithink it was the inlet port)??? and it would pull the oil into the compressor. Try it, if it doesn't work connect your vacuum pump to the discharge port. Been too many years since I messed with one.
    Dec 2011
    louisiana
    Thanks, I had finally figured it out, I put the pump on the oil discharge port (stood the unit upright) and pulled the measured amount of oil in to the suction side of the unit.
