Thread: Adding a return
    Jun 2012
    Adding a return
    Hi all:
    A couple of years ago my contractor replaced my old A/C only 2 ton 10 SEER York with a 14/15 SEER 2.5T Goodman with variable Air Handler (16x20). Each of 4 bedrooms has it's own 8x8 return, except the master BR which is 12x12. Since that time, the return 12x12 in the master bedroom howls as if the unit is starved for air or velocity is too high. None of the returns in the smaller bedrooms make any noise or are blocked. None of the duct work was changed when the unit was changed. I understand you can't have to much return and I'd like to add another 12x12. My question: I'd like to avoid cutting sheet metal to tap into the return plenum. Can I put a metal T into the 12" line coming from the 12x12 and put another 12x12 in the MBR? IOW will the 12" flexduct handle 2 12x12 returns and cut down the noise? So I'd have 2 12x12 returns joined through 12" flex. It would be about 8' between returns in the MBR. From what I can see 12" will pass 600CFM.
    The other idea was to cut into the metal return duct and run a separate 12" return. It's just that the space is difficult to work in and cutting in the T would be a piece of cake.
    I hope I'm making this clear. My thanks to anyone responding.
    Another return, another run back to the plenum.
    Jun 2011
    Houston area
    Ditto x 200%
    The picture in my avatar is of the Houston Ship Channel and was taken from my backyard. I like to sit outside and slap mosquitos while watching countless supertankers, barges and cargo ships of every shape and size carry all sorts of deadly toxins to and fro. It's really beautiful at times.....just don't eat the three eyed fish....
    LMAOSHMSFOAIDMT
    Saint Joseph, MI
    The ductwork should have been evaluated when the size of the system was increased. Actually it should have been evaluated regardless... especialyl going to vairable speed. A system that was previously short of airflow, migh have underperformed, but not been too moisy. A VS will run at much higher RPMs attmepting to reach the correct CFM. This can make the system very noisy and actually consime more power than a standard blower.
    Just curious, why did they upsize? IF the old sysetm was marginal, it's rpobably because it had issues or a dirty indoor or outdoor coil, or was shrot on airflow.
    Philadelphia, PA
    You should hire someone that understands airflow to evaluate the duct system. 600 cfm through 12" flex even if installed perfectly will be noisy.
    Jun 2012
    Added a 10x10 to the system and it's much quieter now.
