Results 1 to 8 of 8
    Jun 2008
    Saint Leonard, Md.
    compact air handler
    need to replace a 3 ton carrier split system. air handler is in attic with a 20 inch access opening. does anyone know a manufacturer who makes an air handler less than 20x20? doesn't matter how tall it is...thanks!
    Time to make a bigger access...
    NE Alabama
    Ditto larger access. Your not going to change the AC handler often but sizing the handler on access hole is not a good idea.
    Jun 2008
    Saint Leonard, Md.
    okay...thanks guys...may be stepping away from this side job...lol
    Jan 2001
    Pamnyra VA.
    What size is the return grill?
    Jun 2008
    Saint Leonard, Md.
    the same...i need 2 look at the trim on the attic access closer...already know the old unit has 2 b taken apart. it is much larger...wonder why ppl wait till 90 degree weather 2 have a 36 year old unit replaced...lol
    NE Alabama
    Because they aren't inconvenienced until it doesn't work
    Aug 2010
    West Monroe, LA
    Quote Originally Posted by skibme View Post
    Good question!!! I think I know where you are going on this one. If the return is bigger then the attic access take it up there that way. I have done this Many times. Also do you have room to cut in a bigger return air grill? If so you can take it up that way if the current return is to small to do so. Also alot easier to fix by adding a bigger return.
