Results 1 to 7 of 7
    Jun 2012
    changing from r-22 to r-410--lineset question
    Hi,
    We're replacing our attic split system, changing from r-22 to r-410. The contractor explained his plan to replace all the lineset they have access to, but that they plan to reuse the existing vertical lineset going down 2 stories inside the wall (after cleaning it out). He explained that if I wanted a new vertical lineset, they could do it going down the outside of the house.
    Question: Is it okay to reuse the (inaccessible) vertical portion of the lineset, or should I get a completely new one from end to end for the r-410?
    Appreciatively,
    Pittsburrito
    Jun 2011
    Hammond,La.
    I would use 100% of the old line set if it was the correct size and not damaged. Simply loop the liquid and suction line together and feed two cans of flush through the liquid line followed by nitrogen. You do not want couplings all over the place if you can help it IMHO.
    Quote Originally Posted by Rcb2875 View Post
    I agree. As long as they flush it correctly.
    Jun 2012
    Are the linesets for the different coolants the same size? I had heard they were different sizes under ideal circumstances (total lineset replacement), to withstand different pressure. Did I understand that wrong?
    Aug 2009
    Michigan
    I would replace the line set.
    Jun 2011
    Hammond,La.
    Quote Originally Posted by pittsburrito View Post
    The line sets are all the same copper tubing for every refrigerant. The size depends on the unit.
    NATEanator
    Additional infractions may result in loss of posting privileges.
    Your post has been deleted.
