Results 1 to 8 of 8
    Jun 2012
    Installing heat pump as conventional ac
    Taking your advice from my previous post, I am leaning towards not installing a heat pump as a heat pump in my Cleveland area home.
    What my installer would like to do is install the older model American Standard heritage 14 heat pump as a conventional ac unit, so the heat pump capabilities cannot be used. Why? Well, he has a bunch, and we can get it from him for less than the American standard Allegiance 13 ac unit.
    According to him it is no big deal. He will hook it up and it will function just like an ac unit. Will it really? Again, I would appreciate any feedback or advice.
    Houston,Tx.
    Quote Originally Posted by Luckky_lassy View Post
    According to him it is no big deal. He will hook it up and it will function just like an ac unit...
    He is correct, if he has half a clue, he can do this with no issues, go for it!
    Massachusetts
    It's no different than having a street wide enough for cars to travel in both directions but by law, limiting travel to only on direction. Same thing for the HP used for cooling only. I would assume it's faulted to heat so he'll need to power the 4-way valve continuously. If it ever goes into heating mode, you'll know the power source tot he 4-way valve is interrupted or the 4-way valve coil is fried. Otherwise, you'll never know it's a HP.
    Still think it is dumb not to wire as a heat pump. If you don't like it, you don't have to heat with it. Haven't had a homeowner complain yet about their dual fuel system.
    Aug 2009
    Jurupa Valley, CA
    The only reason I wouldn't want the heat pump in there is there are just more components to fail. And most of those components are designed to fail to heating. That said, having dual fuel capability couldn't hurt, just would require the proper stat to properly utilize it.
    Northeast Ohio
    I agree, why not install it as it was intended? The only difference is the control wiring. I have tons of duel fuel systems out there with nothing but happy customers.
    DEM
    Dec 2010
    Chicago, IL
    Thumbs up
    Agreed!
    Jun 2012
    Thanks folks. We have two more estimates coming in tomorrow, but we are leaning heavily to this contractor and this unit. If we go with him, I think we will have it installed as it should be with the appropriate thermostat. From there, we can decide if we want to ever use it for heating. Again, thank you for your time and advice.
