Also your other option would be to install a zoning system on your existing sytem. This will put a thermostat in your basement and your basement registers until it is satisfied. With this though you may need a furnace / air handler that can provide Variable air volume, which could get mor expensive than getting a seperate system just for the basement.
No matter what, adding registers or return will most likely not work well.
