    Jun 2012
    converting oil burner to gas
    I am currently converting 2 hot air oil fired furnaces to gas with Wayne p250AF power-shot burners. Both furnaces also have central air. I'm a little stumped on the final low voltage wiring as well as wiring the fan limit switch. I've converted boilers before but not central heat with air. Need some help please.
    you will not get the PRO help you need here, as the RULES for this site prevent it.
    just FYI
    Massachusetts
    I thought you were changing the fuel source, not the wiring source. In our state you need a gas fitters or plumbing license to change from oil to gas, either LP or natural. Perhaps not in your state?
    Virginia
    Probably woild be better off with a new gas furnace
    burlington county n.j.
    Quote Originally Posted by catmanacman View Post
    no doubt about it, would be better with a gas furnace.
