Results 1 to 7 of 7
Thread: Dryness in home
    Jun 2006
    Up North Some PLace. Brrrrr.
    ok i have a issue with a house being too dry. a/c running at to 74F. Person getting nose bleeds cause of dryness. possible solutions to the problem. run the humidifier to add mosture. ask to turn up a/c?
    Jun 2006
    what state is this in and whats the RH in the house
    SW FL
    REally ?
    PERSON getting nose bleed because of
    WEAK BLOOD VESSELS.
    Designer Dan
    It's Not Rocket Science, But It is SCIENCE with "Some Art".
    Jun 2006
    toronto ontario canada. ya i thinking same as weak or close blood vessel but doctor says otherwise
    What is the average RH and dry bulb temperature during summer and winter?
    Requirement for right sized air condiditioning has to be supplemented with calculations or sensible heat gain and loss, latent heat gain and loss, room slope, and comfort zone data are some of the basic information you need to start with.
    Ask a reputable contractor around you to design a suitable HVAC system for you.
    Some general reading:
    http://www.air-conditioner-selection...ing-guide.html
    http://www.air-conditioner-selection...er-sizing.html
    May 2002
    Colorado
    Your air flow may be too low. Have an HVAC professional see if it can be increased.
    Madison, WI/Cape Coral, FL
    Increase the air flow will decrease latent removal. Operate the fan continuously. TB
