    May 2012
    North Alabama
    Condensor fan running backwards
    I changed out a burn out fan motor on the condensor and put a new 7.5 cap. as the motor required. It worked fine for a week or so... now the fan when it starts up goes back and forth and about half the time runs backwards. I reversed the leads, changed the cap just in case it was a bad one. Any suggestions......
    The Hot South
    Is it wired up right?
    May 2012
    North Alabama
    it worked for a week without issue...
    had another go bad on another house .... same fan motor... wired up without issue and still running
    two leads to the relay
    2 leads to the cap.
    Lancaster PA
    jmo90280, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Further infractions may result in loss of posting privileges.
    BradMahoney
    Additional infractions may result in loss of posting privileges.
    Your post has been deleted.
Tags for this Thread
