Results 14 to 16 of 16
    May 2012
    Thank You Guys For The Information. CraziFuzzy, Do You Know How Well The Geothermal Works With Radiant?(Heating And Cooling)
    Aug 2009
    Jurupa Valley, CA
    I don't have direct experience with it, but geothermal should work as well with radiant as it would with anything else. It's just moving heat, so the smaller the difference between evap and condenser, the easier it is to move said heat. If the ground is warmer than the air, it will heat better than an air source unit. If the ground is colder than the air, it will cool better than an air source unit.
    Not sure I agree with doing any sort of 'radiant cooling' though...
    Oct 2013
    Newberry SC
    Aqua Products, and several others.
