Results 1 to 10 of 10
Thread: Mega flo
    Apr 2012
    Pasadena,Maryland
    Mega flo
    Picked up my mega flo evac kit today at abco,can't wait to take it for a test drive.
    May 2010
    Canada
    Let me know how it goes. I'm thinking of getting the setup.
    Apr 2012
    Pasadena,Maryland
    I will as soon as I figure out how to use it,has four ports on back of manifold I have no idea what they are for. No user manual or connection diagram. I can see how to hook the suction and discharge and the short vacuum hose up, then it's got these 2 garden size hoses,I have no ideal what to do with them.maybe someone who has one will give me a clue.
    Austin, TX
    1.) MegaFlow Gauge Manifold
    2.) 6-Foot, 3/8"FL to 1/4"FL, 3/8" Dia. Blue Hose
    3.) 6-Foot, 3/8"FL to 1/4"FL, 3/8" Dia. Red Hose
    4.) 6-Foot, 3/8"FL to 1/4"FL, 1/2" Dia. Black Hose
    5.) 6-Foot, 3/8"FL to 1/4"FL, 1/2" Dia. Black Hose
    6.) 6-Inch, 1/2"FL to 1/2"FL, 1/2" Dia. Black Hose (TEZ8 Connection Hose)
    7.) 6-Inch, 1/2"FL to 3/8"FL, 1/2" Dia. Black Hose (Universal Vacuum Pump Connection Hose)
    Two core valve removal tools
    A and B =MegaFlow Vacuum-Rated Valve Core Removal Tools
    Step 1: connect #2 to Low side of #1
    Step 2: #3 to high side #1
    Step 3: to the middle port of #1 connect either #6 if you have a 1/2 port on your vacuum pump if not connect #7 1/2 to #1 3/8 to vacuum pump.
    Step 4: connect A to suction line removing the core from the scheider valve and connect #2 to core removal A
    Step 5: Repeat step 4 using #3 and core removal B to liquid line
    Step 6: Connect #5 3/8 to vacuum pump and 1/4 to valve core removal B
    Step 7: attach a micron gauge to core removal A OR repeat step 6 with #4 to core removal A.
    If you're too "open" minded, your brains will fall out.
    Artificial intelligence is no match for natural stupidity.
    Apr 2012
    Pasadena,Maryland
    Used my megaflop speed kit today,it worked fantastically,installed new ac condenser and coil.hooked up kit,took less than 1/2 hr to pull down below 200 micron.i would have left it hooked up longer but the boss was so impressed he thought it was low enough. Was worth every penny if I keep getting these results.
    Mar 2006
    I just got 2 of the appion core removers and 2 3/8 4 foot (maybe 3 i dunno) hoses. works good for me
    You can't kiss death without it kissing you back. Death is a passionate kisser.
    May 2010
    Canada
    how much did it cost you?
    May 2009
    South of Heaven
    The CRT's are the most important part because they allow for complete isolation from the pump ( and whatever contraption is used to connect the pump to the system ). However , the best " contraption " to have would be a Megaflow kit for sure.
    Apr 2012
    Pasadena,Maryland
    About 6 bills
    May 2010
    Canada
    Quote Originally Posted by Flashg21230 View Post
    About 6 bills
