Results 1 to 10 of 10
Thread: Mega flo
05-30-2012, 07:12 PM #1
Mega flo
Picked up my mega flo evac kit today at abco,can't wait to take it for a test drive.
05-30-2012, 10:02 PM #2
- May 2010
- Canada
- 287
Let me know how it goes. I'm thinking of getting the setup.
05-30-2012, 10:11 PM #3
I will as soon as I figure out how to use it,has four ports on back of manifold I have no idea what they are for. No user manual or connection diagram. I can see how to hook the suction and discharge and the short vacuum hose up, then it's got these 2 garden size hoses,I have no ideal what to do with them.maybe someone who has one will give me a clue.
05-30-2012, 11:47 PM #4
1.) MegaFlow Gauge Manifold
2.) 6-Foot, 3/8"FL to 1/4"FL, 3/8" Dia. Blue Hose
3.) 6-Foot, 3/8"FL to 1/4"FL, 3/8" Dia. Red Hose
4.) 6-Foot, 3/8"FL to 1/4"FL, 1/2" Dia. Black Hose
5.) 6-Foot, 3/8"FL to 1/4"FL, 1/2" Dia. Black Hose
6.) 6-Inch, 1/2"FL to 1/2"FL, 1/2" Dia. Black Hose (TEZ8 Connection Hose)
7.) 6-Inch, 1/2"FL to 3/8"FL, 1/2" Dia. Black Hose (Universal Vacuum Pump Connection Hose)
Two core valve removal tools
A and B =MegaFlow Vacuum-Rated Valve Core Removal Tools
Step 1: connect #2 to Low side of #1
Step 2: #3 to high side #1
Step 3: to the middle port of #1 connect either #6 if you have a 1/2 port on your vacuum pump if not connect #7 1/2 to #1 3/8 to vacuum pump.
Step 4: connect A to suction line removing the core from the scheider valve and connect #2 to core removal A
Step 5: Repeat step 4 using #3 and core removal B to liquid line
Step 6: Connect #5 3/8 to vacuum pump and 1/4 to valve core removal B
Step 7: attach a micron gauge to core removal A OR repeat step 6 with #4 to core removal A.If you're too "open" minded, your brains will fall out.
Artificial intelligence is no match for natural stupidity.
05-31-2012, 07:49 PM #5
Used my megaflop speed kit today,it worked fantastically,installed new ac condenser and coil.hooked up kit,took less than 1/2 hr to pull down below 200 micron.i would have left it hooked up longer but the boss was so impressed he thought it was low enough. Was worth every penny if I keep getting these results.
05-31-2012, 08:06 PM #6
- Mar 2006
- 948
I just got 2 of the appion core removers and 2 3/8 4 foot (maybe 3 i dunno) hoses. works good for me
They told me to use the brain God gave me.
I did.
Now I'm an Atheist. Ironic, isn't it?
05-31-2012, 09:12 PM #7
- May 2010
- Canada
- 287
how much did it cost you?
05-31-2012, 09:24 PM #8
The CRT's are the most important part because they allow for complete isolation from the pump ( and whatever contraption is used to connect the pump to the system ). However , the best " contraption " to have would be a Megaflow kit for sure.
05-31-2012, 09:25 PM #9
About 6 bills
05-31-2012, 09:26 PM #10
- May 2010
- Canada
- 287
