Results 1 to 10 of 10
    Oct 2005
    This is always how it starts....so I have a friend of a friend who wants a 4 ton HP install. So my friend installed this unit for him. For some reason he thought that 13 seer hp's use r410a. So he fired up the system and added about 1/2 a pound of r410a before he notice that it's r22. Question is... what are the potental problem?????
    Jul 2002
    Zelienople, Pa
    The entire refrigeration circuit will need to be replaced.
    I was told the mixture turns to a black tar-like substance.
    Nov 2001
    Not so fast,
    I remember seeing Jed Clampit, making alot of money from a black tar-like substance.
    Oh sorry that was make believe on TV.
    jsin, you need to buy your friend a new unit.
    If you try to fail, and succeed.
    Which have you done ?
    Jan 2002
    Ft.Worth,Tx
    Recovery,drier,vacuum and recharge with R-22
    'Life begins with the journey each day'
    Jun 2001
    Louisville, KY
    Somebody lied to you.
    As posted, recover, change drier, vacuum, recharge.
    Feb 2005
    Alabama
    benny, I was told the same thing at a 410a class. If the 2 mix it produces a nasty sludge in the bottom of the compressor which can result in failure.
    "If you can't fix it, don't break it."
    SE Michigan
    I think I remember something to this effect being said at the carrier puron class when the sheit first came out.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Houston,Tx.
    Not to mention it is against Federal Law to mix refrigerants.
    Let me edit this a little:
    It is against Federal Law for us to mix refrigerants.
    [Edited by mrbillpro on 07-10-2006 at 11:24 PM]
    The only way is to evacuate it into a properly labelled cylinder to be destroyed.
    Then evacuate and remove moisture, leak test, and recharge with R-22 only.
    The system should be able to live another life
    Of course, all of these have to be done by a certified contractor. Handling refrigerant is a serious business
    Nov 2005
    I mix refrigerants all the time for cascade systems.
