Results 14 to 19 of 19
    Nov 2009
    Syracuse NY
    The wire is 14 g and it is stranded !
    St Paul, minnesota
    if it only runs correctly with all heads running, then it is definitively cross wired. this needs to be corrected 1st, then remove all refrigerant, evacuate and weigh in the charge. good luck
    Nov 2009
    Syracuse NY
    Did that !
    All the wires are in the right location direct from each unit to the right terminals on the outdoor unit also I forgot to mention that I had already evacuated the system remeasured all the line set lengths and recharged the system by weighing the charge in after the last time I had the flare leaks I may have a dud on my hands .
    Quote Originally Posted by superfittertech View Post
    midwest
    Called in for problem outdoor unit aou36rml completely fried.....not worth the labor to touch it. so call for pricing its obsolete and new unit wont match up to indoor units??? system is 2 years old customer is pissed which I don't blame them but Im in the middle of this now. Any recommendations of a brand to retrofit this mess over to? I want to keep the piping and wiring in place if possible.
    “The price of anything is the amount of life you exchange for it.” – Henry David Thoreau
    It's sad that we have become so accustomed to bad service that we're shocked when we get good service.
    Neil Cavuto
    Orange County NY
    Fujitsu has an excellent parts warranty!
    No other brand will work with the existing software on the indoor board.
    In a boiler room
    Quote Originally Posted by hvacdoctor View Post
    Wow old thread.
    What's wrong, and why can't you replace the bad parts?
    Worry is a really gross misuse of one's imagination. -- PHM
